[gallery] La-5FN Modelik
Discussion in 'Aircraft & Aviation' started by KPawel, May 22, 2008.
  1. KPawel
    KPawel New Member
    Hello everyobdy!
    I'd like to show some photos of my recently completed card model, famous soviet Lavochkin La-5FN:
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Finally, in its final destination under the ceiling:
    [​IMG] [​IMG]
    I'll be looking forward to any comments :)
  2. col. kurtz
    col. kurtz Member
  3. KPawel
    KPawel New Member
    The model is mostly in its natural printed colors, although I 'rubbed in' some dry chalks powder on some areas to mask joints and damages to the print. Finally the model was covered with acrylic varnish to get it look less 'paper'.
  4. logicman
    logicman Greybeard
    It most definitely doesn't look like paper.
    That could easily pass as plastic.
    Top notch.:thumb::thumb::thumb::thumb::thumb:
    (mucha nie siada)
  5. SCEtoAux
    SCEtoAux Member
    Looks real good. The rubbed in chalk and the protective spray gives it a nice realistic look. :thumb:
  6. Wily
    Wily Member
    Frankly, I'm blown-away with the finish - excellent work!!
  7. dansls1
    dansls1 Member
    She's a beaut - thanks for sharing ;)
  8. Nemesis7485
    Nemesis7485 Member
    That really is an excellent looking model. Marvelous job.
    What make of acrylic varnish did you use?
  9. lriera
    lriera Member
    It looks awesome. It really doesn't seem build with paper.
  10. KPawel
    KPawel New Member
    Thanks for your very nice comments :)
    Nemesis7485 - the brand I used was 'Amsterdam' matt varnish from 'Talens' (spray).
  11. Nemesis7485
    Nemesis7485 Member
    Thanks for the info, Pawel. I'll be getting me some of that.
  12. exzealot
    exzealot Member
    Wow! I am also blown away!. I like the way you engraved the panel lines and rivets.
    Beautiful job!
  13. Romanator
    Romanator Member
    There are no seams! How is it possible! I never imagined such compound curves could be possible. Great work. :thumb: How do you do it?
  14. :thumb:Very very nice indeed. Keep it up and you will be an expert in no time.-------Just kidding!! You are already an expert :p
  15. mgolovanov
    mgolovanov New Member
    Excellent model. What paints did you use for colouring the cut edges of the paper?
  16. KPawel
    KPawel New Member
    Thank you :)
    For the edges I use the "Tempera" paints (I'm not sure how they call it in english) - they are water-soluble paints which you can mix on a pallette to obtain desired colour and dry it out. It is then ready to use by rubbing the wet brush on it.
  17. cjwalas
    cjwalas Member
    Beautiful job! The finish is absolutely excellent. A most impressive effort!
  18. I.Nicolae
    I.Nicolae I.Nicolae
    I dont have any questions,I just wnat to say: GREAT JOB !!!!!!
  19. ustercluck
    ustercluck New Member
    excellent job on one of my favorite planes
  20. gregh
    gregh Member
    very very nice build. thank you for the pictures and finishing tips
