Front wheels for steam loco
Discussion in 'FAQs' started by Scoobie, Apr 12, 2006.
  1. Scoobie
    Scoobie Member
    I have question. Can you buy the front wheels for a 0-6-0 steamer? I beleive it's called the " drive wheels"? I guess I'd like 0-6-0 into a 2-6-0. Is this possible?
    Thanks Scoobie
  2. MasonJar
    You cannot necessaruly add the "pilot truck" to a 0-6-0. Although the prototype often rebuilt engines, it is not always that easy to do. It depends on the manufacturer of your 0-6-0.
    The drive wheels are indicated by the second number in the description - 0-6-0 has 0 pilot wheels, 6 drivers (three on each side) and no trailing wheels (under the firebox).
    There are a couple of guys here at The Gauge that are really talented with loco modification - post a bit more info about what you want to do, and what you are working with, and I am sure you can get some more help.
  3. Scoobie
    Scoobie Member
    Thanks Andrew, you are so heplful. What I was thinking of doing is - my son got a Bachamnn 0-6-0. I'd like to add some " pilot wheels " to the front. Is this a big deal or is it as simple as buy and putting them on. It looks like there might be a mounting screw on the bottom of the loco.
  4. ezdays
    ezdays Out AZ way
    Like Andrew says, it's going to depend on your loco. You might be well off looking around for some scrap locos at a swap meet or even a train shop. Or even look as other locos and see how the pilot trucks are mounted and see if you can adapt yours. There's a good possiblity that if you do add a pilot truck, it's going to stick out too far in front, or interfer with your drive wheels.
    I'll bet if you were able to post a few pictures or a more detail description of what loco you have and who made it, someone here can be more help to you than we can.
  5. MasonJar
    I don't know the specifics of that engine, but many manufacturers use(d) the same frame for X-drivered locos - i.e. same frame for 0-6-0, 2-6-0, and 2-6-2 for example. So if it looks as if there is a mounting hole, it may in fact be that simple.
    I would contact Bachmann directly, or go the their website and try the "Ask The Bach-Man" forum. They should be able to supply parts. If not, there are a few manufacturers that offer "aftermarket" details like the pilot truck.
    You will have to check the clearance and so on, and possibly change some of the front end details. Take a look (search) for projects by member Ray Marinaccio - he is a wiz with engine rebuilding/modification.
  6. Scoobie
    Scoobie Member
    Thanks again Andrew, it sure looks like the Bachmann 0-6-0 & 2-6-0 are the frame. I will contact Bachmann. Do you think Kadee would have pilot wheels? To be honest, the more I get into this train hobby the more I'm shying away from Bachmann, the quality doesn't seem a good as others. That's my opinion and I'm no expert.
    Thanks again,Scott
  7. davidstrains
    davidstrains Active Member
    Years ago Kadee and Microtrains use to have conversion sets for some locomotives. I changed an Atlas 0-8-0 to a Consolidation 2-8-0 with one of their "pilot conversion kits". You might check out the Kadee website to see if they still make the conversion kits. Other manufacturers may also do them, but since I am in "N" I don't know much about the HO products available.
  8. MasonJar
    At the risk of opening up the debate yet again, I would offer that my experience with Bachmann has been pretty good. My original train set was Bachmann, and a few years ago, I took it out of more than 20 years of storage, put the loco on the track, and away it went. This particular loco is a heavy, full metal frame with a decent motor. Is capable of pulling almost every car I own...!
    My second Bachmann experience was with the "toy" quality set that most people associate with Bachmann. I bought an engine with one of those cheapy "pancake" motors - rear wheel drive only, pickups on 4 wheels only. But that is what I wanted, as I sliced of the back of the chassis to kitbash a Galloping Goose. So no disappointment there, as I knew what I was getting.
    My recent Bachmann experience is with the Spectrum Line. I have a Ten-Wheeler that I am very happy with. Performs well, and the details are great. Took a bit of tweaking to get it going (including decoder installation, some re-affixing of details, and shortening of wires between loco and tender which snagged on point rails).
    However, "your milage may vary" as they say... ;)
    To answer your question... I do not know if Kadee has an appropriate part. "Miniatures by Eric" might have something suitable if Bachmann doesn't come through.
  9. Scoobie
    Scoobie Member
    I agree with you Andrew. The track on our layout is Bachmann EZ track & we have now 3 Bachmann engines. This all got started when Granpa bought my 7 old son a Bachmann set last christmas. Now we ( he ) has 4x8 layout in his bedroom. We love it and are almost finish with layout. I guess I was venting on my last post as I'm having problems with one of the switches sticking. So, next time I'll be more specific and not attack the whole Bachmann line of goods. Didn't mean to affend anyone!!!!!!
    As always thanks for help!! I send you a picture whenn we're done.
  10. pgandw
    pgandw Active Member
    Bowser has lots of steam engine parts, including the old Cary line, Bowser, Varney, and Penn Line. Precision Scale - which took over Kemtron - also makes pilot wheels. NWSL is another good source for after-market pieces, including pilot wheels.
    Hope this helps
  11. doctorwayne
    doctorwayne Active Member
    If your 0-6-0 is a Bachmann, and if they also make the 2-6-0, then contact Bachmann for the necessary parts. You can check on their website, but you'll get better results with a 'phone call.
    For Parts or Service in North America:
    1-800-356-3910 - Press 1 for Parts, or go to either extension 11 or 17
  12. Dragon
    Dragon Member
    I know Precision Scale made a pilot truck with spoked wheels. I got a handful of them when I was rebuilding my Mantua 2-6-6-2.
    Not sure how available they are now...they were scarce when I got mine.
    I will try to find a pic of it.
  13. espee
    espee New Member
    Go to Northwest Shortline. They have anything you want.
