From 4WD to 2WD
Discussion in 'RC Offroad Forum' started by thegoonman, Aug 17, 2004.
Thread Status:
  1. thegoonman
    thegoonman New Member
    Just wondering how good it is for a car to take out the front drive shaft and just have a 2WD car. I just thought it would be fun for a bit like this but probably not permanet.
  2. monsterrcbuilder04
    i have heartd you get higher top speed
  3. thegoonman
    Thats makes sense becasue there is less of a load on. I kinda figured that but wondered if it would wear the engine or casue anymore damage because it would then be running faster becasue of no load and could blow it up maybe, just wondering, any help would be great.
  4. monsterrcbuilder04
    well i think any damage would go to the driveshafts or if its a street car maybe even the drivebelts.there would be more tourgue going to those 2 wheels
  5. thegoonman
    Good enough for me, even if it breaks the drive shaft it doesn't really matter there cheap and it would have to have a lot of torch on it. As long as i keep it on loose ground there should be no problem. Pavement might casue it to break but loose ground shouldn't should it.
  6. dj6666969
    dj6666969 Active Member
    hey check this out. I had a duratrax street force (if you dont know its 50+ MPH!) and 1 of the pullys got a rock into it and I could only run it as a 2wd, well for a onroad car, trust me you need all 4 wheels LOL. The thing mostly just wanted to do donuts! Wiht I truck you could go for the 2wd but I dont think so on a Sedan, just to much power, and such alittle car!
  7. monsterrcbuilder04
    well if you make it 2wd make it front wheel drive. rear wheel might flip too easily
  8. tnx
    tnx Member
    doh front wheel, thats what i said then the car will follow the front wheels9 rear wheel drive with make it drift to much)
  9. dj6666969
    well when m street force went to #@$% I couldnt make it into front wheel drive cause of the pully so I could only go rear untell I bought new parts for it!
  10. tnx
    tnx Member
    oh, that sux[xx(]
  11. monsterrcbuilder04
    well thats good for drifting.lol
  12. tnx
    tnx Member
    ya lol. my id rather not drift to much :)
  13. dj6666969
    well let me tell you I dont know if it had to much power or what but drifting wasent a option, just more of going strait for a short distance and then spinning out lol Ypur tryed to turn you spun out, every time! I did manage ti get it going strait for about 15 feet and then I hit something and busted alot of stuff on it, that was the last tiem I ran it lol!
Thread Status:
