Free Model #3 - White Knight by JM
Discussion in 'Aircraft & Aviation' started by Lex, Feb 14, 2008.
  1. Nothing
    Nothing Longtime Member
    do you use scissors only? relooked at the build and just a fabulous build!!
  2. logicman
    logicman Greybeard
    your model is clean, square, accurate and finished.:thumb:
    I'm jealous.wall1
    Good luck in the competition.:thumb:
  3. Lex
    Lex Dollmaker
    Thanks Nothing and Logicman ^^
    Yes... I think me and scalpel just doesn't mix... I only use a small knife to cut otherwise inaccessible holes below 2mm diameter. But I'm trying to get used to it as I think I'll need it on commercial kits... ;)
  4. Mark_1984
    Mark_1984 Guest
    You can't beat a scalpel and steel rule for a straight edge. I fine scissors better for curve though.
  5. milenio3
    milenio3 Active Member
    Lex, is it possible if you can explain a little more how you did the wheels?
    It is a very pretty aircraft! Too bad the JM site is dead (any problems with the neverending story of piracy?). Good I have mine from way back.
  6. DavidESP
    DavidESP Member
    Nice job Lex, you set the standards high for me and the other's in the competition.
    I like to use scissors for most of my cuts, although I use an OLFA cutter for some of the smaller cuts and the interior cuts.
  7. Lex
    Lex Dollmaker
    Oh really?! I didn't realise your Judy was built with scissors too... (Shakes hands) :D Your build is going along nicely, keep it up!!
  8. DavidESP
    DavidESP Member
    Thanks Lex. Here's a shot of my favorite par of scissors:
    They have a real nice pointed tip, almost as sharp as a cutter.
    The hole punch comes in real handy too.
  9. Lex
    Lex Dollmaker
    Thanks!! I never knew a handheld hole punch existed! I might have to try that one day... ;)
  10. Hans Christian
    Hans Christian Active Member
    Now that's a big DARN IT...
  11. Hans Christian
    That's the cleanest build of sir jan's kit that I ever saw... great job!!! :-D
  12. Lex
    Lex Dollmaker
    I don't think Jan had a c*******t problem... I think it was something else that brought the site down... I'm emailing Jan to see what happened
    Sorry didn't see that... I laminated the wheels on thick card, and then used a file to file the wheel to a round profile, I then used plastic glue to reinforce the edges, before colouring it with black marker, that's all!
  13. outersketcher
    outersketcher Illustrator, Tinker
    Wow, nice work Lex. Dangit... now I'm gonna have to build this one too. I have a suggestion for the weight problem.
    Awhile back, I built an old-fashioned model robot I bought from the Lighthouse Model Art going out of business sale.. anyway, that robot also had balance problems. What I ended up doing was to inject some liquid epoxy resin into the base of the feet. The epoxy resin filled the lower cavities and settled that robot right down nice and solid. Epoxy resin is heavy stuff man. Course, this would only work on a model that has been sealed with clearcoat. Otherwise, I think the liquid epoxy might soak into the paper a bit and discolor it.
  14. Lex
    Lex Dollmaker
    Thanks for the suggestion!! If I could get my hands on some epoxy then that's a great idea! --Meanwhile if that doesn't work I'll be forced to make another SpaceShipOne ;)
  15. milenio3
    Well, Lex, your method on the wheels are just the same as mine, thou your is cleaner!
  16. Lex
    Lex Dollmaker
    I coated the wheels in superglue before the final filing, maybe that hardens the wheel's surface and makes the result a bit cleaner ;)
  17. milenio3
  18. Maico Shark
    Maico Shark Guest
    Beautiful work
