fox trucks
N
nachoman
Anyone have any info on the "fox" style trucks supplied in a few old MDC kits? What era were they used and on what types of applications? Did this design have any advantaes/disadvantaes? I'm thinking about using some for variety sake on my wwI era layout, and I am not sure if they would be appropriate.
Kevin
sumpter250
multiscale modelbuilder
Jan 19, 2002
3,073
Vernon Hills, Illinois
Kevin,
The "Model Railroader's Guide To Freight Cars" (Kalmbach Publishing) covers trucks from the WWI to present, and makes no mention of Fox trucks. I know this isn't much to go on, but I would believe that Fox trucks were "in absentia" by the WWI era.
I would recommend that you do not use them for interchange service, but I see no reason why you couldn't use them for MOW equipment, especially if you are freelancing your own road.
If you are modeling a known railroad, I would think you'd be able to find pictures of that road's MOW equipment, to see if any Fox trucks were used.
N
nachoman
Thanks for the replies. I take it, they must not have been a very proven design, and must have only seen limited use prior to 1900. Maybe I will stick them on a work car or two, for conversations sake.
Kevin
nkp174
1,455
Cincinnati, O.
I've found a few posts on the Early Rail forum...here's a sampling...
" Joe,
I can recommend Page 469 of "The American Railroad Freight Car" John
H. White, Jr., Johns Hopkins University Press.
Tom"
With regard to a wreck on the Colorado Midland...
" Another one upside down with FOX trucks, so probably NYC something or
other" (that was 1903)
Another
" I did a drawing of an Santa Fe (GC&SF) box car that had Fox trucks with
outside hung brakes. This car ended up in M-of-W service and then
became living quarters for track workers at Allensworth CA."
I also found a post mentioning a New England road using flat cars with Fox trucks into the 1970s, although it appears their era was 1890-1910. It was the primary truck of the PRR for 1890-1905
Here's a couple more posts:
" wrote: I have seen pictures of two types of Fox trucks, one with only
coil springs over the journal, and the other with coil springs above
the journals and leaf springs sticking out of the center of the side
frame. I would presume that the latter were to allow some equalizing
function.
The Fox trucks with the blank side panels between the journals have
the truck bolster plate rigidly fastened to the side to side transoms.
The Fox trucks with the leaf springs sticking out the hole in the
center of the sides have a "floating" truck bolster. That is to say,
the truck bolster that directly contacts the underside of the car then
sits on those leaf springs. The bottom of the leaf springs are then
mounted to a plate on the bottom of each side frame. What holds the
bolster in place are the side transoms and straps across the top of
the transoms to keep it (the truck bolster) from popping up when
removed from the car.
This arrangement probably provides a limited amount of side to side
flexibility and some extra cushion and a much improved ride but no
direct equalization per se as one would get using levers and so on as
in a passenger truck.
Actually, from what I've read, neither the Fox nor the various types
of arch bar trucks provided true equalization. However, the sloppy
tolerances and inherent flex in the metal bars of the arch bar design
provided a "practical level" of equalization far superior to the Fox.
Hence the Fox truck was prome to develop stress cracks on the
relatively rough US roadbed which led to its going out of favor.
Bob M."
and
" Yes, Fox Patent trucks would still be in use in 1910. They also lasted on
non revenue cars until those cars were scrapped or sold to logging lines, etc.
The East Branch & Linloln RR in New Hampshire bought old flat cars from the
B&M that had Fox trucks and they were used until the 1970's, on their line,
carrying pulpwood. I thought that I posted a pic of one of these cars."
puddlejumper
254
Southern Maryland
The oldest piece of rolling stock on Conrail's roster was a snowplow, equipped with fox trucks that had been converted with roller bearings. I believe it was in service into the 1990's. I do not know if it made it to the CSX/NS split.
Dave
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
The Gold Coast Railroad Museum has a tender with Fox trucks under it! I think the loco dates to 1913 (labelling was scarce). Can't really tell how accurate it is, whether the trucks are original or not, etc. They are the ones with leaf springs under th bolster. Interested in a photo?
N
nachoman
Wow, thanks! Those are definitely some unique trucks. Now that I can see more how they are constructed, it makes sense that they were phased out shortly after 1900. Arch-bar trucks were made up of several pieces bolted together. I assume the arch bar design had a weakness because of all those bolted joints. These riveted fox trucks were probably stronger. But once cast sideframes came about, the arch-bar and the fox were obsolete.
Kevin
