Fokker D-VII... 1/33
Discussion in 'Aircraft & Aviation' started by eatcrow2, Apr 24, 2007.
Thread Status:
  1. eatcrow2
    eatcrow2 Member
    finishing the bottom wings
    Thanks Jim... All credit has to go to the designer, as all I have to do is not screw it up...;-)
    Here I've glued the bottom wing to the fuslage.. Sure do like the look of the lozenge camo scheme.
  2. cmdrted
    cmdrted Active Member
    i agree, looks pretty cool, good job on her! Will be watching anxiously for you about adding that pesky top wing. One of the biggest reasons that I build more modern aircraft!
  3. eatcrow2
    eatcrow2 Member
    Louvers & tail assembly
    Have added the louvers to the engine panels, and glued on the tail assembly.
  4. Clashster
    Clashster Member
    Great job, Peter! Especially like the photos of the louvers - they look absolutley real! Thanks for the update!
  5. Jim Krauzlis
    Jim Krauzlis Active Member
    Beautiful work, Peter!
    Keep at it, mate!
  6. Amazyah
    Amazyah Senior Member
    Very nice work, Peter!
    The little details are fantastic!
    Those are the parts that really bring a build to life!
  7. eatcrow2
    eatcrow2 Member
    Hi Carl...
    Yes, the louvers really help in giving a more realistic look to the model.. The lozenge IMO is some of the best I've seen on a cardmodel.. Matches up well with some old "Americal Decal sheets" that I still have from the plastic days, and I always thought they were the top of the line for being well researched. With all the wide options of colorings for the Fokkers, it would be nice to see some more releases of this kit in other markings.
    Have completed the top wing... Everything fit without any problem.
    frames for the wing..
    completed wing..
  8. Rev
    Rev Member
    Nice job.
  9. Buki
    Buki Member
    Excellent :grin: ...
    The only mistake: Kartonowa kolekcja is the name of new quarterly (journal) :twisted:
    The business name of publisher is Profile :oops:
  10. CharlieB
    CharlieB Member
    Beautiful build Peter. I wish I had my new monitor so I can see the actual colors.
  11. eatcrow2
    eatcrow2 Member
    Hello Buki... Believe me, by the time I'm finished that will not be the "only" mistake...;-)
    Made up all the control surfaces, but will add them later once I have the top wing mounted.
  12. eatcrow2
    eatcrow2 Member
    A study in patience....
    What I'm messing around with while I'm waiting on some stiff wire I need for struts.. Curious to see if anyone would guess what kit this is from, what I've done..;-)
  13. eatcrow2
    eatcrow2 Member
    Helps to include the pic...
  14. I need a Pin up girl. . .
    stiff wire
    the project looks cool, some type of pre 1917 plane?
    I did an experiment with a plane I built called the Travel Air Mystery Ship from It takes a lot of wire. I tried several diffrent things and I settled on carbon fiber rod. Just a thought for you, plus depending on the scale the thickness's available might not work. . .
  15. Jim Krauzlis
    Not sure which airplane this is, since I'm not that familiar with aircraft (perhaps an FE2?) but it's obviously an excellent build!
    Will you treat us to more pictures of this build?
  16. eatcrow2
    eatcrow2 Member
    Jim... they are over here.
  17. Jim Krauzlis
    Thanks, Peter!
    As expected, I was wrong.:grin:
    Superb build!
  18. lv4142003
    lv4142003 Member
    Peter, how is the build coming along? <lv4142003>
    NULLMOON Member
    is it just me or am i seeing double and the begining of this thread:confused:
    gotta love ww1 camo
  20. lv4142003
    lv4142003 Member
    Eat... how is the build going? It really looks good so far. Did you get the wire you were looking for for the struts? <lv414203>
Thread Status:
