Discussion in 'Getting Started' started by NCMRailroad, Oct 19, 2006.
  1. NCMRailroad
    NCMRailroad Member
    Hi folks,
    Well, I think I came up with a solution to my problem. I went to visit a fella who has a railroad that takes up 90% of his basement. I described to him what my situation was and he explained how he constructed his road bed.
    It all seems very simple however I have one question now that never came to mind earlier.
    Because I have an over/under section located on my layout which takes a bridge of any kind to allow the track to pass over the other I need to know what to do about the elevation at that hight and at that perticular section. To get somewhat of an idea of my track I should explain that where it crosses over one another is like the mid section of a figure of 8. I really don't want much for elevation as my layout really doesn't allow it because of its length. (16 feet aprox.)
    Any suggestions will be GREATLY appreciated and thanks in advance.
  2. alexander
    alexander Member
    OK, if i get what youm mean, your having problems with your track height
    if you have it so that the bottom track is flat, and the top one climbs, thats not ideal
    the ideal situation, is, having yout lower track gow down, then up, and, your top track rise and fall, so, both share the grade.
  3. 60103
    You'll need a bridge with very little underneath. You may need something a bit stronger than plastic under the track if the clearance is tight and the bridge long.
  4. rfmicro
    rfmicro Member
    Bridge Incline
    A 4% incline is about the maximum you should use on any layout. That equates to about a 4-inch rise per 8-feet of trackbed. You certainly have the room to accomodate the rise. Woodland scenics makes an incline lit that you could use. Place the bridge or structure in the middle of the rise and continue with the incline.
