Floquil "Driftwood"
Vic
1,699
Columbus GA
Hi Casey, I've been using Floquil SP Lt. Lettering Grey thinned about half and half. Seemed to be a pretty good match:) I haven't seen the CN Grey but Floquil is kinda "sneaky" some of the colors are the same just a different name!!!:eek: :D
Try some Floquil Concrete thinned out. It makes an interesting/nice stain too. Any of the regular Floquil colors will make stains just thin them down:D :)
farmer ron
377
B.C., canada
Casey, I located a can of mini wax stains at the paint store, they are a large company that makes many stains so should not be hard to find. They make a driftwood stain and I got some in a small can. Test it first to get the right consistancy as it does need thinning. Much cheaper than hobby paints. I also use a couple of their stains for tie stains and other wood stains. Ron...
Ron - Several times in the last few months I looked at Minwax in Walmart and Home Depot but could never find anything close to "Driftwood." Maybe I should have tried a regular paint store :rolleyes:
I did use a Minwax oak stain on a board-by-board water tank/shed model. I liked the way the stripwood took the stain until I tried to weather it. My black alcohol mix just rolled right off because the stain had pretty much rendered the stripwood weatherproof. Not exactly what I anticipated or wanted to happen. :( As a result, all of the weathering was done with chalks alone, instead of my usual black alcohol/chalks "combo."
Vic, thanks for the tip on the SP Lettering Gray. I think I'll get that and the CN Gray and try both. If there's enough difference in the shading, it could make for some interesting variations in weathering.
BTW: I frequently use "stains" made from earth-tone acrylics, water, and Inda ink. I soak entire batches of stripwood in them before beginning b-by-b projects.
