First weathered boxcar
Discussion in 'Weathering Forum' started by Cornreaper, Nov 16, 2006.
  1. Cornreaper
    Cornreaper Member
    Well, here is my first weathering attempt. I took a cheap shiney Lifelike N-scale boxcar and did a wash of alchohol/India Ink, then went nuts with the chalk pastels. I didn't dulloat the final layer of chalk, i'll touch it up if necessary. Still have to do the trucks though.
  2. Herc Driver
    Herc Driver Active Member
    Nice effect. I like the discoloration on the white lettering.
  3. MilesWestern
    MilesWestern Active Member
    I think you did a splendid job, you might want to rust the galvanized steel roofs around the seams though, like the prototype! Also might want to invest in a $3 N scale kadee roof walk (if they make them) and shave off all those unsightly round things holding the current one in place. :) Good work
  4. TruckLover
    Looking good
  5. Cornreaper
    Cornreaper Member
    Thanks! I wasn't even going to use this on my layout, but now that it's weathered, I might just take your suggestions and toss it in the mix!
  6. UP SD40-2
    UP SD40-2 Senior Member
    Cornreaper, WOW!!!:eek: Thats your first weathering job? DEFIANTLY put it on your layout!:thumb: . :D -Deano
