first timer need help
Discussion in 'RC Aircraft & Watercraft' started by paulio, Dec 30, 2003.
Thread Status:
  1. paulio
    paulio Guest
    i have an instructor and i think he wants to start me on an avistar arf, is this a good plane Is there anything else that can do mmodest aerobatics but still is good to train on
  2. Steve M
    Steve M Member
    The Avistar ARF is a nice trainer and it will easily loop and roll once you've earned your wings.
  3. Fastsky
    Fastsky Member
    The Avistar is a great flyer. If the plane is the one your instructor suggests then go with it. It means he probably has experience with the plane and knows what to expect from it, which helps. Just make sure that you get the version that is covered in Monocote. It makes it easier to repair if needed. The Avistar is actually a good all arounder. It is fairly aerobatic, flys well in the wind, can hang on the prop and also fly inverted. Just take it easy on the throttle for a while. The plane is light weight and fast with a 40 and a rocket with a 46. With experience thats half the fun!![8D]
Thread Status:
