Fiddlers Green DC3 for Minium equipment
Discussion in 'Radio Control & Other Propulsion Methods' started by meatbomber, Aug 27, 2008.
  1. meatbomber
    meatbomber New Member
    Here is my lates flying "card" model :)
    I used a Fiddlers Green DC-3 Set, enlarged it to A3 size (149%), and used it as templates for a durobatics foam build (0.05in or 1,2mm thick)
    The results are very nice, super gentle slow flier with a Wingspann of 63cm, weight 35g and wingload of only 6,5g/dm²
    The RC equipment used was Kyosho/Parkzone Minium Cessna 210 brick, motors, props and akku... everything stock.
    Still missing a bit of colour, but that will get on next :)
  2. NYC Irish
    NYC Irish Member
    wow well done, thats a great piece of work
    John John
  3. scon10
    scon10 Member
    That is amazing! Would you have any flying photo's??
    What is exactly durobatics foam? Is it the same material used in shockproof packaging for stuff like printers etc? But is bendable and gluable? I am intrigued.
  4. meatbomber
    Thanks guys :)
    Durobatics is a Polysterene foam thats probably a cut from Depron foam which is very popular here in Europ for building light weight slowfly models. you can get it at
    This airplane has flown already but no photos, i`m just about to colour it in CSA colours.
    This is already the MK2 :) my first DC-3 was built as an Austrian Airlines plane, flying videos can be found here:
    First flights with Mk1:
    Outdoor flying in Austrian livery:
  5. @ skon 10,
    The stuff is called 'Roofmate' in Holland, architects use it in sheets to build maquettes, It's availble from 3mm to 5cm, I don't know where you live in Holland, but I get it from an art-supply shop called "Harrolds" in Rotterdam
    Cheers, Billy
  6. abiallan
    abiallan New Member
    hi dude
    wat an awesome experiment u did:wave:
    chanceless engineering desidn man.. hatts off.
    may i know the total weight of the craft nd the motors description plz:cry:
  7. meatbomber
    All up weight 45g and the equipment is from the Parkzone / Kyosho Minium Cessna 210... 6mm coreless brushed motors with a 4:1 gearing.. as available as spare parts for that plane
  8. ZoeBaur
    ZoeBaur New Member
    wat an awsome experiment u did! gud..keep it up!!sign1
  9. DarrenBarrow
    DarrenBarrow New Member
