I think you are running into the same problem I've recently come to realize - the wood is not scaled correctly. This past weekend I was at Hobby Town to get some scaled wood for a N Scale fence I want to build. I want the fence boards to be about {scale} 6" wide (and 3/4" thick). The smallest basswood strips I could find were scaled to be 4" by 4"...and they are tiny tiny tiny. I'll end up using them but it is the same as building a fence in your backyard and using 4"x4" post as the fence boards themselves. I think part of what is making it look too big is that the roof boards are too thick. Its hard to tell by the photo but I'd guess the scale to be about 12". That would be like having a shed with roof boards 1 foot thick. Get an N scale ruler and check it out if you can (http://www.hobbylinc.com/htm/ctt/ctt9160.htm) and see what it scales out to be.
Randy
Looks good and it seems that you've done the best of your spare time.Chad said:I had some spare time this weekend and built a shack and a winch tower. I think it looks "okay" but the shack is missing a chimney.
You can buy corrugated tin sheets in HO, don't know about N scale. I've also seen folks use ribbon cable from scrapped computers to model corrugated tin.Chad said:How do people simulate a tin roof?
RC BOAT said:For a corrogated material wrap tin foil around the threads of a bolt, carefully flatten out and cut to look like panels, glue to card board and weather. You can tear a corner, bend a corner, punch a hole in it to look rustic. You can also soak tin foil in vinegar for a few days to seriously etch it and eat away at the edges.
George
RC BOAT said:Randy;
It worked for me, try setting it in the sun to warm it up, just don't let it dry out. The acid in the vinegar should react with it.
George
