Fat Albert
Discussion in 'Gallery & Designs' started by Gil, Oct 16, 2006.
  1. Gil
    Gil Active Member
    Not Yet...,
  2. Bowdenja
    Bowdenja Active Member
    Shoot man............. I wouldn't change a thing, they look great.
    Is it some kind of accordion fold and glue thing?
    Is it a single cut piece?
  3. airbob
    airbob Member
    C-5 Project
    Hurrah! for tackling this project!!!....the big jets are really challenging.....your use of RHINO to develop this project is really inspiring.....I only wish that I understood how to use this system....maybe before I die!? :cry:
  4. Alcides
    Alcides Member
    The rhino model is inspiring and the paper prototype looks great. Go go !!!
  5. Hans Christian
    Hans Christian Active Member
    Sir Gil, any news on your C-5 sir? :-D
  6. Gil
    Gil Active Member
    Hello Hans Christian,
    I had an unfortunate disk catastrophe several months back and lost a lot of data that was not current on the backup..., The C5, however, survived the disaster and is in the queue.
    Best regards, -Gil
  7. Hans Christian
    Oh I see... Thanks for the heads up sir!!! :-D
  8. cmdr199212
    cmdr199212 Member
    now that is soooooooooooooo true!!!!!!!!!!!!!!!!!!!!1going to see them in july!!!!
  9. RyanShort1
    RyanShort1 Member
    Hey Gil,
    Has the queue moved up any? I for one am always interested in the little tips and tricks you post... and would really like to see how a finished design of yours turns out! Also, a C-5 model would be really popular here in San Antonio. I know a guy who is one of the flight instructors for the C-5 here in town.
  10. RyanShort1
    RyanShort1 Member
  11. astralwanderer
    astralwanderer New Member
    any more news on this project as I too am interested in the C5 and would really like to get one to build
  12. aphelion16
    aphelion16 Member
    Just to stir the name pot some more. To a aircraft junkie who grew up in Dallas, TX, "Fat Albert" was the first bright orange 747 that Braniff International bought. They got it specifically to fly round trips from Dallas to Hawaii and back. They were told that you couldn't work an airplane that hard. But Al did just fine, flying out of Love Field. Long before DFW existed.
  13. Gil
    Gil Active Member
    New Content...,
    The C5's been in sleep mode for several years. The design was put on hold as the amount of accurate information was sadly lacking. Since then I've acquired several tools which with photographs from web sources has enabled extraction of details that aren't available anywhere outside of Lockheed/Martin...,
    Below is a beauty shot of the new work so far. It's interesting that as the design progresses that an understanding of the immensity of the design and tradeoffs made by the engineers at Lockheed becomes apparent. This monster is a streamlined freight train - only bigger...,
    The nose to cockpit cabin transition was a nightmare to get tangent. The shape of upper rear fuselage was another story altogether. Half way through I remembered why I took a break from it the first time around.
    The wheel fairings still need work. They're not tangetially surface transistioned but shouldn't be that much of problem.
    The surface envelope is now nearing completion and with that the transition to panel line marking. If this goes to model the next phase is section matching and framing. Some sections will require the application of modeling paste and sanding. It just would not look right otherwise. This will not be a print colored bird but a spray coated one instead [but all paper in the inside].
    Bien Cordialement, +Gil
  14. Gil
    Gil Active Member
    Gray Scale
    Had the usual "snakes in the cockpit" till the right set points were found in the properties dialog and lofts were arranged to enable seam closure. Color is near that of the full size aircraft...,
  15. montee916
    montee916 New Member
    Can't wait to see the final result. :thumb: Even tho I guess I'll have to. :p
  16. Zathros
    Zathros Guest
    That's one helluva render Gil. Interesting to see some of these old threads being revived, n'est-ce pas?
    "The first shall be last, and the last shall be first"...................Matthew 20:1-16
  17. Gil
    Gil Active Member
    Slow But Accurate
    Hi Zathros,
    It takes time to sort through all the question marks a particular subject projects onto a design study.
    Accurately reproducing a subject is exceedingly difficult as one progresses through the process of discovery.
    As any designer soon discovers the three dimensional outline is the beginning; the three dimensional surface is half-way and the whole enchilada takes forever...,
  18. Zathros
    Zathros Guest
    I hope you haven't given this up, it is so awesome.
  19. inky
    inky Member
    I agree with Zathros, I hope you haven't given up on this. I been waiting on a C-5 for some time now.
