F-16 Model
Discussion in 'Aircraft & Aviation' started by tzachil, Mar 28, 2009.
  1. tzachil
    tzachil New Member
    Hi All
    I would like to build an F-16 Model
    can you give my you opinion on which is the best model
    I have the Halinski F-16C as well as the new MM F-16C block 52
  2. exzealot
    exzealot Member
    Typically, Halinski is better for detail and fit in most cases. However, I have not seen the Maly version up close.
  3. Bowdenja
    Bowdenja Active Member
    You will never.... ever.... go wrong with a Halinski Kit! Period! :thumb:
    You can always check out the beta builds on his site........... I don't even think they beta build Maty kits........... well that is an opinion(because of all of the mistakes in color, part alignment, panel line errors, just plane wrong parts, etc...)
  4. sakrison
    sakrison Member
    You might go a little crazy from all the details, :mrgreen: but Halinski kits are, indeed, the top of the line.
    Maly kits have their shortcomings but they are getting better and better. Maly's B2N5 "Kate" is one of the nicest kits on the market. It's nowhere near as detailed as Halinski's "Val" but its fit and finish are very good and it makes a very impressive display model.
    No worries,
