EZ Command and other analog controller
lyjo
3
Does anyone know how or if you can add a non Bachmann analog controller to the EZ Command to run your DC train..
lyjo
3
I think I didn't make myself clear..
There is an option to interface a DC controller through the bachmann ez command (DCC).
The documentation shows a bachmann analog (DC) controller used..
I want to use my non bachmann Analog controller.
Is anyone using a not bachmann through there ez command system?
lyjo
3
Does anyone have a bechman dc transformer to test the ouput on ?
The wire to connect the two is a stereo plug (3 wires) wondering if there is something different on the non track wire?
oldtanker
771
West central Mn
On the Bachmann analog controller.
In the first place they only use 2 wires, the 3rd connector on the plug is not used...I took one apart to see.
Max output on the voltage is 18.45 volts DC no load. Just tested it.
As long as the polairty is correct I don't see why another brand controller couldn't be made to work but you could fry the EZ Command.
Rick
