experience with combining styrene and paper
Discussion in 'Tips, Tutorials & Tools' started by lizzienewell, Jul 23, 2005.
  1. lizzienewell
    lizzienewell Member
    Here's what I've found out. Use superglue to glue styrene to paper.
    For drilling holes in styrene, a drummel tool gets the plastic too hot. It works better to turn the bit by hand. Wrap the end of the bit with tape to get a better grip.
    To thread elastic through small holes in styrene that are too small for a needle, use flat pliers to clamp a piece of thin wire around the end of the elastic. This way you are pulling through only one strand of the elastic, not a double strand.
    Don't print on surfaces that will be glued with super-glue. The glue will stick to the toner instead of the paper and then the toner and the glue stick to your fingers.
    Spray computer-printed pages with matte fixative to keep the toner from smudging.
    For building complex parts out of styrene or other non-paper materials draw the part to size on the paper copy and use it as a template.
  2. Better yet get a tool called a pin vise. Specifically meant for hold small drills for doing hand work. Most come with several size collets for hold ing th whole range of wire size drills. I think General has one for about 5USD
