Evader ST electric motor upgrade
Discussion in 'RC Offroad Forum' started by patj28, Mar 1, 2004.
Thread Status:
  1. patj28
    patj28 New Member
    I have an 8T+ ESC I want to run a 10T motor. Is this going to be really fast. Also can I use the stock spur gear and pinion, or would I have to change this. Please let me know what I would have to change this to if needed. Also would my 1500 batteries run this or would I need larger. Thanks for your help
  2. mastmec
    mastmec Member
    You will have to goto a lower tooth pinion gear, spur gear can stay the same unless the pinion won't reach it, then you will need a larger spur.
    The 1500's will work, just not last very long, short run times. Larger capacity battery would work better though.
Thread Status:
