Engine problem
507wayne
14
Faribault, Mn, USA.
Greetings
I have a problem with a life like GP 38. when I try to run it all that happens is the light lights and a slight hum no movement, any idea what could be wrong.
Thanks
Wayne
sumpter250
multiscale modelbuilder
Jan 19, 2002
3,073
Vernon Hills, Illinois
Is this a LifeLike trainset loco, or a Proto 2000? I've heard that the P2K diesels have a tendancy to have the axle gears split, and slip on the axles. If it is new, take it back to the shop where you got it. They should be able to find out what's wrong, and fix it.
Pete
eightyeightfan1
Now I'm AMP'd
Torrington, Ct.
Sounds like something is jammed in the drive. Like Pete said, something might of split or even just a piece of dirt or something caught in the gears. If you have a diagram, you can take apart the drive gears, clean them and re lube them.
Give this a try...Before the ultimate.....Turning it into a projectile.
N
nachoman
double make sure your track is not conected to the AC terminals on your power pack!!
kevin
