Engine damaged?
Discussion in 'RC General & Getting Started' started by vette_7t9, May 16, 2004.
Thread Status:
  1. vette_7t9
    vette_7t9 Member
    ok, so I ran my new OS engine 1 1/2 - 2 tanks on extremely lean side which made fuel boil in my carb. Will that damage my engine and take away some HP? I am very confused and worried.
    Moved to proper forum.
  2. dj6666969
    dj6666969 Active Member
    ok 1 things 1)why did you run it so lean. It would have been better if you posted this in the engine forum Stevem, can you move this thread
  3. vette_7t9
    vette_7t9 Member
    I am told bubbles in the fuel line aint a problem, and hissing noise is cuz of its hot parts. Any tips>?
  4. dj6666969
    you shouldnt have any air in the fuel line. it doesent hurt the engine but the engine needed a steady stream of fuel at all times
  5. jackal575
    jackal575 Member
    needed lol
  6. dj6666969
    NEEDS my bad lol
  7. John Binz
    John Binz New Member
    Did you break it in becuase it didn't sound like you did becuase you said a 1 1/2 to 2 tanks.
  8. redheat
    redheat Member
    Well it sure didnt do your engine any good to run it lean, as far as temp damage ya you more than likely did some, did you even get it broken in before you ran it lean? Good thing it was a OS there forgiving. Run it a little on the rich side for about 2or3 tanks. Take a look at your plug too they hate extreme heat,replace if the coil is all sprung.
Thread Status:
