editing pdfs
Discussion in 'Tips, Tutorials & Tools' started by RyanShort1, Jul 4, 2008.
  1. RyanShort1
    RyanShort1 Member
    The very best would probably be Adobe Illustrator or Photoshop! Second best would likely be GIMP or Inkscape. The latter are FREE programs that are very powerful. I use both depending on the need of the moment. GIMP is a raster (bitmap) based program. Inkscape is a vector program. Look that up on Wikipedia, and you should get a better idea which way you want to go for your project. There are some tutorials out there, but the best way is to ask questions. There are a number of folks here who can help.
    Either program can open PDFs, but you'll likely want to save the file as something else (.xcf for GIMP or .svg for Inkscape) until you finish your redraw.
  2. David H
    David H Member
    Corel Draw is pretty good too and a lot more common and affordable than the Adobe products.
    IMHO Corel Draw is a little easier to get started with although perhaps not so powerful as Illustrator at the ultimate high-end user level.
    Cannot argue with Photshop. It really is the business!
  3. Lex
    Lex Dollmaker
    Some vector programs have known to have issues opening pdf, so the safest (and most expensive) bet would be Illustrator ;)
  4. David H
    David H Member
    The Author can lock or protect a PDF file to prevent users editing the contents. If you have one of these files you could write to the author and ask permission for an open version.
    Alternatively you could scan the printed PDF file and edit the resulting raster file. Not so neat but a practical expedient.
  5. kneedeep
    kneedeep New Member
  6. Lex
    Lex Dollmaker
    :) Oh well if it's a pdf printer then I'd recommend FreePDF... There's many choices though ;)
  7. Boris
    Boris Member
    To alpinemike
    I've posted here a small tutorial about repainting using Photoshop, try to look it up in my messages. The main principles apply to GIMP also. I have also started using Gimp. I will try some day to prepare an additional tutorial.
  8. Hey that pdf995 works great, thanks
  9. Robot Exodus
    Robot Exodus Member
  10. MuseOfLife
    MuseOfLife New Member
    My brother recommended me to use this PDF Creator. I’m totally satisfied with it.
  11. dwfunk4475
    dwfunk4475 New Member
    This has been extremely useful.
  12. Jef
    Jef New Member
    Try Foxit PDF Editor :thumb: Faster than Adobe ,specialy for weak PC
