dubble track on w.s 2% grade
Discussion in 'HO Scale Model Trains' started by emt49, Mar 8, 2005.
  1. emt49
    emt49 Member
    i am useing woodland secnics 2% grade and i want to run a dubble track will i need two sets of the risers or will one work
    and if i need to use two will the inside grade be longer because the inside run is shorter than the outside
  2. belg
    belg Member
    In N scale you could probably get two on one but not in HO your clearances won't make it fit. I would also be careful in N if your radius is to small and you run large cars and locos they could interfere with each other. Test it with your largest car and a pencil draw where the overhang is on the outside one and plan the interior around that one,Pat.
  3. nolatron
    nolatron Member
    like said, it'll work fine on straights. I did the same thing. But curves, they're too close together for long cars. You'll need a 2nd incline piece at the curves to give you some more clearance.
  4. guppyman
    guppyman Member
    Here's a thought, not sure if it would work, but it's something I have considered doing....
    If you took the 2% risers and put a piece of foam on top of them, your foam would then be at a 2% grade. This could be wider than the risers and allow for double tracks around the curves without a problem.
  5. belg
    belg Member
    guppyman, I think that would be a great way to save money but then you would have to either cut down the riser the thickness of the foam on top or continue that foam all the way around to keep the same height. Pat
  6. Connor
    Connor Member
    You can use a piece of foam on the side of the inclines to extend the width a little, maybe 1/2 or so, which should give you enough clearance on curves for longer cars. My WS book shows this being done for N scale applications and double tracks.
  7. emt49
    emt49 Member
    cool thanks for the info guys i think ill try and see what i can do with some foam
