Dr Theopolis 1:1 scale from Buck Rogers
12,338
Hi fans!
This is gonna be something easy: Dr Theopolis from Buck Rogers. The pattern I'm making is supposed to fulfill two tasks at the same time: First, it will be rescaled to become an accessoire for my Lego-Twiki. Second, it is supposed to be turned into a life-size prop.
The original prop was very crude and simple and is an ideal candidate for another paper model.
Here are the first WIP pics of the different layers:
paper back drop
mouth and eyebrows
eyes
shell
The white circles mark the positions of the lights.
CU soon! :)
9,854
This is going to be SO VERY COOL!!!
I am GREATLY LOOKING FORWARD TO THIS!!!
I guess, I will have to find some LEDs for this project!
12,338
I guess so, too! ;-)
acrylic / plexi glass layer (grey):
The final model / prop will be 9" / 22,86 cm in diameter.
9,551
Didn't watch buck Rogers much, so I had no idea what you were talking about, for the uninformed, like myself, i have posted a picture. :)
12,338
If you wanna build it with lights you will need 18 red LEDs (5 - 7 mm), 2 white LEDs (10 mm), 8 warm white LEDs (5 - 10 mm).
12,338
Wow! Thank you, Zathros! I didn't have this pic in my archive...:)
This shows one most important thing: The shell is NOT GOLDEN. It is a mix of gold and green metallic which changes its tone depending on the surrounding light. I'm wondering if I'll be able to find a similar piece of metallic card for that... :rolleyes:
12,338
Hello, Ron!
Great to see you here! Believe it or not, the original prop had absolutely NO detailing on it except for six ICs, two resistors , two capacitators and some wire! o_O Nearly all components were flat pieces (which makes this prop ideal for papercrafting, BTW). If you take a closer look you will notice that Theo was made in a hurry, from the cheapest materials available. The cutouts were messy and they even glued the ICs to the backdrop upside down! :p
Theo looked that good on screen because the resolution of TV screens were relatively low in the late 70es/ early 80es and the flickering of the lights and the reflections caused by the acrylic front plate hid the imperfections very well. I guess a BluRay release of the show would be very revealing... :D
I'll try to match the original as closely as possible, however, my lines and cuts will be straight and precise! ;)
To ASC: Making it in 1:18 scale would be quite a challenge. I'm looking forward to seeing how you are going to shrink the LEDs to make them fit..! :D:D:D
9,551
Sometimes, you stumble on stuff on the Internet in the weirdest ways. As far as "shrinking "LED's", remember, you can mount LEDs in a Lath or similar device and take then down, as long as you don't go too thin and expose the metal parts, or leave too little plastic , and oxygen gets in, they they go "poof". They can be shaped, and the ends milled to make them reflect differently. Facets can be put on, polishing them with jewelers rough makes them really shine. :)
Draegor
26
3
I loved this show back in the day, although I'm a bit sad that disco roller-skating never did catch on as the entertainment of the future. ;)
E
eagleclaw4935
Great idea doing Dr. Theo,all the Buck Rogers fans should love this one.Biddy! Biddy! Biddy!
bgt01
Exemplary Confidant
Jan 26, 2012
576
843
93
Ohio
This is the kind of stuff I live for in this hobby! Somebody get me a Doctor!:D
Ron Caudillo
Creative Advisory Consultant
389
313
Davenport, Iowa
Hello, Ron!
Thanks for that! I've always enjoyed yours posts and projects. This is turning out quite nice. Great bunch here!
Best Regards,
