EngineerKyle
Hi Crew!
The double helix…. I could use some technical advice and general specifications for a helix…. I’m planning a new section and I’d like it to be about 12-18 inches higher than my current layout. I figured I’d put a helix in the corner, disguised and a hill or something, to get my trains up to the new level. I was wondering if anyone has built a “double” helix (and I don’t me Watson and Crick) so that a train could go up the helix, say on a 22” radius, run around the upper level and return down the same helix, on an inner, 18” radius line?….. I thought I would cut some C shaped pieces of luann (that thin plywood sub-floor) and splice them together for the base surface of the helix. I have seen some pics of helixes that include threaded rod in their design. I thank you in advance for helping me get this off the ground.
Kyle
Kyle
