I plan to doubledeck my layout, when I find time. I lost about 200 sq. ft. of my layout room to other family requirements: luckily only the benchwork was finished. I redesigned the trackplan (sorry, I don't have one available to show :cry: ) and came up with a "Y" shaped main line. The stem of the "Y" runs from the existing staging to South Cayuga, with the right "arm" in place from there
down to Port Maitland. The left "arm" of the "Y" is completed around the empty-appearing peninsula opposite South Cayuga.
The existing staging is all stacked in the area shown, with that for Port Maitland at 36" above the floor, and bi-level staging for Dunnville at 39" and 44", the same level as the main lines there. These two lines converge near Negro Creek at an elevation of about 42", then climb to 44" at South Cayuga. Here, the two lines split, with the line to Elfrida crossing the Speed River on a downgrade, then plunging into a tunnel that curves around the outside corner of the room, ending up at about 39" above the floor in Elfrida. The line continues down on a fairly gentle grade, reaching 36" at Lowbanks, the same as the staging opposite Port Maitland.
The other line that split off in South Cayuga crosses the Speed river on a curved viaduct built on a 2.8% uphill grade which continues up the peninsula opposite South Cayuga, curving around the end and then heading back towards Elfrida, all the while climbing. At the crest of the grade, just above the start of the town of Elfrida, the tracks will be about 60" above the floor. Track will continue around the room at that height, across another lif-out section at the doorway, and into another single-ended staging yard.
Here's a crude drawing showing the layout room, which is about 560 sq. ft. My plans are to build a second level over the grey area in the drawing. The long peninsula opposite South Cayuga is the grade up to the second level, and is in place up to where the yellow area ends. There'll be a town at the crest of the grade, above Elfrida, and a larger city area over Lowbanks/Port Maitland, with more staging above the existing staging yards.
The benchwork, probably 3/8" plywood on 1"x2" pine, will be supported on angle-iron brackets, bolted to the walls. These have already been fabricated, and are designed to also provide support for a number of 4' double fluorescent fixtures, which will be hung beneath the upper deck to illuminate that part of the layout already in place.
When finished, the layout will operate as a point-to-point-to-point, with trains travelling between the upper deck and Port Maitland needing to be broken up and re-arranged at South Cayuga. This should provide lots of operation, in addition to straight run-throughs between Dunnville and both the upper and lower endpoints.
I hope to take photos as construction progresses, but it's already over a year late in starting, with no target date even in sight. :cry:
Wayne
