I haven't picked out a throttle yet, but does it connect directly to the bus wires? Also, what power pack (volts and amps) do I need to power lights and turn outs? Thanks for the help guys/gals.
ezdays said:Welcome to the Gauge. I'm assuming since you said "throttle powe pack" that you mean DC rather than DCC. The DC output would indeed to to the power bus except in cases where you are running blocks. Those are sections of track that are isolated from the rest so that you can run multiple trains, or you can stop one train on a siding or yard and still run another one. You may also have a second power pack on the circuits as well. In these cases, the DC power output goes to the switches and the switches go to the blocks of track.
The MRC Tech4/250 will run several HO locos. I've got two Tech4/350's only because they were running a nice sale at the time. They also have a steady 12 volt DC output and an AC output to run accessories, lights and turnouts. If you need more accessory power you can always buy a cheap power pack or even use a plug-in pack like you use to charge batteries on a cell phone or CD player. They come in both AC and DC outputs.
Hope this helped.
