Does anyone know how to find the scale weight of an item?
Discussion in 'Tips, Tutorials & Tools' started by pashlispaht, Oct 6, 2004.
  1. pashlispaht
    pashlispaht Member
    I have a question for any of the more mathematically astute members of the audience. Does anyone have any idea on how to find the scale weight of an item? For instance, if a particular tank weighs 40 tons at 1:1, how much would it weigh at 1:25? This is assuming that the density is also scaled as well. I hope someone out there knows the answer to this...
  2. Maurice
    Maurice Member
    Weight, like volume, varies with the cube of the linear scale.
    (1/25)x(1/25)x(1/25) = 1/15,625
    and your model of a 40 ton tank will weigh
    40x2240/15,625 = 5.7344 lbs or 40x1000/15,625 = 2.56 kg
    Assuming that your talking about one of those tons that weighs 2240 lbs or 1000 kg and not one of those tons that weighs something else. :D
    Density of course does not get scaled - it is weight/volume and that is the same as (scaled weight)/(scaled volume).
  3. SteveM
    SteveM Member
    Isn't 1000kg a "tonne" while a "ton" is 2000 lbs.?
  4. charliec
    charliec Active Member
    Depends on whose "ton" you are referring to - the old Imperial ton was 2240 lbs - I think the US "ton" was/is 2000 lbs. The metric "tonne" is pretty close to the Imperial ton.
    Why 2240 lbs? - an Imperial ton was 20 hundredweight (cwt) where 1 hundredweight (cwt) was 112 pounds (lbs) or 8 stone (and 1 stone was 14 lbs). Can't imagine why we went to metric units....
  5. Renaud
    Renaud Member
