Torpedo said:OK, but I thought prototypes typically run 13' spacing, which I make to be about 1.8 inches for HO. Do they run less in the yards, or do I need a refresher course in math? ops:
I looked at that, and measuring with a ruler and calculating based on the known standard track gauge of 56.5 inches, I still come up with 13 feet on center. Something doesn't add up.brakie said:Not for the yard tracks..Here is a look at the spacing.
http://www.railpictures.net/viewphoto.php?id=55613
As you can see there is very little space left between the tracks.
Triplex said:Either you're measuring side-to-side instead of center-to-center, or that's N scale.
I calculated the same thing. I also did a web search trying to find a reference to parallel North American standard gauge track of any kind with less than a 13' center to center distance. I could not find anything. I'm sure there must be something out there, but I can't believe it is as little as 10 foot 10 inches.cidchase said:1.5" center-to-center in HO scales to 10'10-5/8" in real life. AAR boxcar width is 10'-8". That would give you less than 3" clearance between cars. I have measured the track spacing in an industrial yard in Memphis and it was 14' even.
Brakie, 1.5 inches doesn't compute, as a couple of us have mentioned, and while looking for something else, I stumbled on this post you made over at Trains.com where you indicate you use 1.75 inches in your yards:brakie said:I like 2" centers..I really like your track spacing..You see I do not and will not accept derailments as part of my operation plan.
Food for thought on yard track spacing..
For yard tracks I like 1.5" inches so it looks like a real yard.
Like so.
