disassembling
pupparo
51
Jensen Beach Fl USA
Does anyone have a method for removing roofs on plastic buildings. I need to remove a roof so I can install a hopper in side the building. I have to tell you it is really glued. Don't know what type glue used since I bought the building assembled.
Thanks for any thoughts:confused:
George D
229
Yorktown, VA
I don't think you are going to get a satisfactory answer to that question. If the building was assembled using styrene cement, the plastic pieces were essentially welded together. That means you are going to have to cut the pieces apart, which ain’t gonna be pretty.
George
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Since your building was pre-assembled, it might be that the walls and roof were molded as one piece, making it even more difficult to seperate them.
If you are really determined to do this, you might try heating the blade of an xacto knife and see if you can't seperate them that way. Remember, this is just a suggestion. I've not ever tried this so if it doen't work, don't blame me...:D :eek:
Don
F
Fred_M
Try 1/2 drop of nitro. You only get one chance though. Some preassembled building are heat melted together. Most are welded with solvent (glue). Sawing is about it. DASH
C
Catt
What type of building are we dicussing here.Do you have a picture of it or a simular one? It would be much easier to advise you as to an effective method of doing what you want to do.
shaygetz
3,612
www.freewebs.com
If the glue is old, then it usually can come apart by CAREFULLY working the joint. I redo many older, previously assembled buildings and find it not too difficult to do. Newer joints can often be parted by carefully running a sharp knife along the joint, then working it apart as before. The key word is patience, it can be done.
P
philip
A product called oops will separate testors and tenax. Works for me. Test a small area first.
philip
ezdays
Out AZ way
Feb 3, 2003
6,339
Arizona
bigbluetrains.com
Originally posted by jon-monon
Pretty big fine print, Don :D :D :D
Uh, I write technical manuals and proposals and this is kinda a standard high-tech weezle-word disclaimer that you'll find in just about everything you buy nowdays. Only as you implied, it is normally in about one-half point type :p :p :p
Don
Blake
446
Northern New Jersey
www.BlakeDTatar.com
Try this.
shamus
Registered Member
Dec 17, 2000
3,489
UK
Try running a brush dipped in liquid Poly cement along the edge, it should soften the edges enough for you to remove it, before it re-glues it. I have done it before.
Shamus
F
Fred_M
Too much labor, try this...
F
Fred_M
That explosion picture looks like a mad cow getting ate by the thing. DASH
