dimming an led headlight
N
nachoman
i have installed a white LED for a headlight on a narrow gauge steamer. The reason for using the LED was for longevity because replacing said bulb would be a real pain requiring removing many details.
the problem is, the LED seems a bit too bright for what I would want. Any thoughts on how I could make it dimmer?
kevin
N
nachoman
the white is more or less permanent now. I have played around with several resistor values, but nothing seems to dim it much. It is either very bright or slightly less bright or off.
kevin
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
One of the guys at the local club has had success dipping the white LEDs in yellow paint to dim them, and give them a more appropriate colour for steamers. He simply dips the LED straight into the paint jar - without stirring the paint first. This "thinned" coat seems to do the trick.
Andrew
Squidbait
Recovering ALCO-holic
Jan 27, 2007
1,219
Paris, ON
That's a problem with LEDs, they require a minimum voltage to light (~5V), and once they're lit, increasing the voltage doesn't really increase the output.
I'd say if you can't paint the LED, see if you can get a transparent paint to wash the lens with (I'm assuming it's in a headlight) and see if that dims/colours it a bit.
baldwinjl
399
LEDs are basically on/off devices. You could control the current, and hence decrease the brightness by tweaking the resistor, but it would take a fairly specific value, and it might change over time and/or temperature, so it really isn't a good plan. The other way to dim it (apparently) electrically is to flash it on and off (quicker than you can see), but that would require some electronics. So you are left with the mechanical means mentioned above.
pgandw
1,002
kevin
Kevin
Inserting a small 1/4 watt potentiometer (tune with a plastic screwdriver type) in series with the LED will probably do the trick. I would try for a pot about 3X the resistance of the existing resistor. If circuit currently has a 1K resistor (typically 500 ohms-1K), add a 3K pot. Too much resistance in the pot (5K ohms) is better than too little (1K ohms) for experimentation with dimming.
An LED typically is at full brightness at around 20ma (and should not exceed 20ma current), and begins to light around 5-10ma. There isn't all that much range for adjustment, but it can be done.
Once you have established the additional resistance to dim the LED, you can add a fixed 1/4 watt resistor instead of the pot if you prefer, and the required resistance is commercially available.
hope this helps
N
nachoman
hey, thanks for the tips everyone. I've got drawers full of resistors to play around with. If I can't do anything with those, I will try coloring the bulb.
kevin
