Digitrax Zypher?
Jim T
79
Warrenton, OR
www.freewebs.com
I've got the Zypher and it works great for me. However, I don't have anything to compare it to as I just got into model railroading last fall. I have it on a 4 x 8 and don't see any problem expanding it.
Jim
davidstrains
1,014
Stafford, VA
There are modules available from Digitrax as well as a couple other distributors for short circuit and reverse loop control. The digitrax unit is a DPM42. Each DPM-42 has 4 sections which can be configured as short circuit protection for 4 power districts, or set up to do automatic reversing on 4 reverse loops or any combination thereof. I am using 2 of the modules, configured for 5 power district s/c protection, 1 reversing section for my turntable and 1 additional s/c protection for the turntable.
Blake
446
Northern New Jersey
www.BlakeDTatar.com
I also have been looking into the Zypher and I think it looks like a pretty good deal. With those reversing units, stay away from the MRC ones if you run allot of steam. Gary Pfeil had them and they caused problems with his steam locos.
Gary Pfeil
2,510
Boonton NJ
I don't have the Zephyr, I have the chief, but the Zephyr has the ability to readback CV's like the Chief, which is a big advantage. It's output is limited to 2.5 amps, rather than the more usual 5 amps. Depending on how many locos you want to run at once, this may or may not be a factor. Of course, boosters can be added. In regard to reverse loops, as Blake mentioned I advise to avoid the MRC modules. I now use the ones from Tony"s ( www.ttx-dcc.com ) They work great. I haven't used the ones from Digitrax, I don't want to have to program them.
