Digitrax question
UP SD40-2
2,709
nicknero, i might be able to help you. i have setup layouts with multiple systems, but first i would have to know what it is you are trying to achieve? then i would know how to advise you on what to do:thumb:. -Deano
Gary Pfeil
2,510
Boonton NJ
I wouold think you just connect them with the Loconet and select one to use as the command station. I believe both can be programmed to be just the booster. I don't remember all the Empire Builder specs but I guess its biggest advantage as a command station is more addresses. It doesn't read back cv's. I would make the Zephyr the command station and the Empire Builder a 5 amp booster. I think it's 5 amp.
