Detailed Thunder Fighter Project
9,892
Here are the rest of the photos of the cockpit interior.
Here is the seat.
This is the joystick mount.
The joystick mount in place.
The joystick is in place.
The cockpit interior is now finished to the point where I need to start on the rest of the plane.
Please stay tuned to your local Earth Directorate Broadcasting channels for further updates as they happen.
Thank you for watching.
12,352
Yep, you are frakkin' crazy, you old pirate! :Grin::Grin::Grin:
(OK, I know you are no old pirate but I wanted to use that smiley sooo badly! :D)
This is awesome! The new straps are really gorgeous. BTW, the scale is collector friendly (the models don't need much shelf space :cool: )!
Reactions: Rhaven Blaack
9,892
I prefer the title "PRIVATE CONTRACTOR";)
Thank you for the compliment.
As for the new straps, they do look good indeed. Now if I were building this at the regular size, I would have detailed the strap hardware (slides and buckles).
9,549
I actually got to see it moving!! Yup! I did! :)
9,892
Here is a small update on my progress.
The main body is (mostly) complete.
As you can see, I was able to put the same amount of detail in this as I have with my other builds.
IMAG4817.jpg IMAG4818.jpg IMAG4819.jpg IMAG4820.jpg IMAG4821.jpg IMAG4822.jpg IMAG4823.jpg IMAG4824.jpg IMAG4825.jpg
I will be starting on the aft end (and the engine exhausts) next.
9,892
Here is a small update.
I have finished the aft section and was able to inject the same amount and level of detail in to this, as I did with the other Thunder Fighters that I have built.
Here are the photos for your viewing pleasure.
Cutting out most of the detailed greebles was tough (but as you can see, it was well worth the effort).
9,892
Here are the engine exhausts.
As you can see, I was able to put in the same amount of detail with these as I have before with my past builds (of this Thunder Fighter).
The exhausts are attached.
I will be working on the underside and the front end next.
9,892
Here is another update.
I finished the underside and the landing strut.
As you can see, I added a little detail to the hinge parts.
(Since there are two Landing Gear parts templates on one sheet, I used the parts that I needed for the extra detail.)
The Strut fits snug.
Now on to the front nose cones.
9,892
I haven't been commenting much, but I am still watching your build(s)! Thanks for the inspiration.
Thank you for the kind words.
You can use any and all of the techniques that I have posted in this (or any other) thread.
Next time you pop in, please be sure to click "LIKE" button on the photos that you like. It will show that you have popped in and saw what I have been up to (you can also do this throughout the forum).
Reactions: CrimsonLine
9,892
Here are the front nose cones.
I attached the inner canards.
I have greebled the inner canards.
Next will be the outer canards, main wings, lower wings, and tails.
