designe c-47 help
Discussion in 'Gallery & Designs' started by yaniv, Dec 13, 2005.
  1. yaniv
    yaniv Active Member
    hi all
    i start work on my firs model design using Tim tutrial
    but i have some litel problem
    i whant make a model of c-47 skytrain in 1/33 scal
    somone can please help me with figer out how mach in MM i need for the
    in 33
    i found ovet the net thet the 1/1 scal have...
    Span: 95 ft. 0 in.
    Length: 64 ft. 5 in.
    Height: 16 ft. 11 in.
    1 more thing---> Span = from the most left point to the right point?(if u looking on top view)
    Length: the most left point to the most right point (if u looking on side view)?including tail?
    Height = the most hige pont to the most low point ?including gers?
  2. Rick Thomson
    Rick Thomson Member
    Multiply feet by 12 to give you the size in inches.
    95ft = 1140in then multipy that by 25.4 for the size in millimetres
    1140in = 28956mm divide by 33 for 877.454545mm in 1/33 scale.
    That's going to be a pretty big bird.
  3. shoki2000
    shoki2000 Active Member
    For conversions you can use one of the on-line tools, ea
    Span/Length/Height - you are correct
  4. tausugAir
    tausugAir Member
    Hi, Yaniv ....C-47 is one of my favorite aircrafts!
    I think the dimension in 33scale in mm is Span would be 877.45; Length would be 594.97 and Height would be 156.24! These I derived from Multiplying the 1:1 length (in Feet) by 12 (inches to the foot) and divide the product by 33 ( the scale) and multiply this by 24.5 to arrive at the millimeter dimension...
  5. yaniv
    yaniv Active Member
    thenks u all :)
    yes the c47 is my fivorit airplan like the b17 but for now its only a test designe coz its the fist time i open 3d program and play with :)
  6. darenfranks
    darenfranks New Member
    I actually see something I can reply about!!! I have been a part of this group for sometime, but mostly lurking. I have been building Card models for sometime, and love the hobbie.
    Now, the C-47. Fiddlers Green has a fairly good C-47. I would have to check on the scale. I am building it now, and if it turns out halfway decient, I will post some pics.
  7. tausugAir
    tausugAir Member
    What is your source (the drawings, I mean) in preparing the tracing? I'm also thinking of doing a Tim Perry's tutorial using the C-47 as the basis... My source, obtained from Internet, has some details obscured...Best regards
  8. yaniv
    yaniv Active Member
    i use a drowing i found over the net but looks like ther not good.. have mye good thet u can sher with me?
    i thinking mybe using the drowing in the old IAF card model of the c47
    u can also tray the c47 by flymodel very diteling and nice model
  9. tausugAir
    tausugAir Member
    Yaniv, this is the source of the C-47 ...
    Best regards
    Muhammad (aka tausugAir)
  10. yaniv
    yaniv Active Member
    yes i just work on it :)
    somone please tell me how i cheng the color of the black lines drawing from black to whit? i paint shop pro
  11. Ashrunner
    Ashrunner Member
    In Paint Shop Pro under the Adjust menu, possible buried somewhere else depending on version, is a negative command. Run that which will reverse the black and white, then save the save.
    You might also want to download Convert, a free program which does a lot of different conversions. It can be found at
    My math isn't as good as it used to be, so I really on little programs like these a lot to assist me. I am sure it will be just as useful for you.
