Decoder Question
Discussion in 'DCC & Electronics' started by iis612, Jan 19, 2007.
  1. iis612
    iis612 Member
    Are DCC systems proprietary, meaning will any DCC system communicate with any decoder?
  2. MasonJar
    DCC systems are proprietary. For example, you cannot expand a Digitrax set with Lenz components.
    HOWEVER, decoders that meet the NMRA standards (which is virtually all of them) can be used on any DCC system. In fact, some decoder makers do not make DCC systems at all (e.g. TCS. Soundtraxx). They should also be "interoperable" - i.e. even if programmed by one system, they should function on another.
  3. NYNH&H
    NYNH&H Member
    Boosters and decoders are interchangeable (boosters need custom made adapter cables), but the throttles and command station must be of the same brand. Lenz and Atlas share Xpressnet (which is not a true peer to peer network BTW), and CVP radio throttles can use a base for NCE, Lenz or EasyDCC, but those are the exceptions to the rule.
  4. iis612
    iis612 Member
    I figured out last night that I have a ways to go before I am ready for DCC.
