Decoder Problem?
Discussion in 'Getting Started' started by EngineerKyle, Oct 4, 2007.
  1. EngineerKyle
    EngineerKyle Member
    This ATLAS C425 II quit working this morning. I can hear noise from it when I thottle it up, but it does not move. It has a DIGITRAX decoder and I reset it to the factory settings, thats CV8=8 on this one, and now it runs well again but is MUCH noisier than it used to be....
  2. sumpter250
    If it truely is Digitrax, then you will have to readjust the volume CVs. When did Atlas switch from Quantum sound to Digitrax, or was this your own installation?
  3. EngineerKyle
    EngineerKyle Member
    my own install... update. Now it doesn't run even with the factory reset. Buzzes nicely... louder as a throttle up. I have another decoder from another loco and I'm tempted to test it. I would hate to mess something up, howerever.
  4. SeriousSam
    SeriousSam Member
    you mean it makes noise like if the motor is spinning but the loco doesnt move? could it be one of your gears? or is it an electrical buzz noise?
  5. myltlpny
    myltlpny Member
    Did you inadvertantly set your acceleration or starting voltage too high? I set the acceleration on one loco too high one time (thought I was setting another CV) and it would just sit there. The lights worked fine, but wouldn't move.
  6. EngineerKyle
    EngineerKyle Member
    i took the shell off, motor looks like this.
