kchronister
So I have a decoder installed that I think I may have fried. Initially I didn't have the motor isolated -- I did all the right things, but was sloppy and didn't test before trying it out. The thing didn't work at all and when I tested the motor wasn't isolated -- I think I must have had some oil or grease on the nylon motor mount screw that was conductive, because when I cleaned it off the conductivity test was fine...
Now that the motor is isolated, the loco works under DCC, but there's no throttle control: It's off or it's full bore. Since I know DCC works with full power on the tracks at all times and the decoder modulates it in pulses to achieve lower speeds, I suspect this means the decoder has blown out... Anyone know a way to test this effectively? Anyone have alternative thoughts -- maybe I connected it wrong (but I doubt that, I triple-checked and I've done more than a few of these now)... Or anyone able to say "yes, it's shot, too bad?" definitively?
Thanks,
Kris
Thanks,
Kris
