decal removal
Discussion in 'Tips & Tricks' started by jimbogibbo, Jan 25, 2007.
  1. jimbogibbo
    jimbogibbo Member
    Can anyone tell me how to get an original decal off of a box car so I can custumize it myself?:cry:
  2. MasonJar
    Is it really a decal, or is it stamp printed?
    To remove decals, try Micro-sol decal solution. It should soften the decal, provided there is not much "top coat", like Dullcote over it.
    To remove stamp printing, try wet/dry sandpaper at 400 - 600 grit. Use it wet.
    In either case, you may need to touch up and/or repaint before you reletter the car.
  3. fwpoppy
    fwpoppy New Member
    I have had good luck using regular Pine-Sol. It may take some testing to determine how long an item should soak. I used it on some Athearn Genesis tender shells and around 45 minutes, I could remove the lettering.
  4. Squidbait
    Yeah, but Pine-sol will lift the paint, too.
    Try using a few drops of Micro-Sol or Solvaset and a toothpick or pencil eraser. You should, with careful scrubbing, be able to lift the decal without lifting the underlying paint.
  5. csiguy
    csiguy Member
    hi all
    i tried removing decals yesterday from a few locomotives and it worked great and wasnt that much work. thank you very much who posted that idea.
  6. csiguy
    csiguy Member
    forgot to add i removed them using a #2 pencil eraser.
  7. woodone
    woodone Member
    Sounds good, glad you got the decals off.:thumb:
    Now on to your new decals or paint.
  8. csiguy
    csiguy Member
    again, thanks again very much, for the advice regarding decal removal. but was wondering if anyone on here has had problems with pollyscale paint? pollyscale jams up my air brush big time and seems to run very bad and leaves a dull finish. just curious f anyone else had these problems and what paint you like the best.
    thanks again
  9. woodone
    woodone Member
    Most of the water base paints will clog up an air brush real quick!- and most are a flat paint. You need to clean the tip often. Need to spray on a gloss coat after you have your base coat done. Polly S make a gloss finish.
    What are you using for a thinner- and what ratio paint to thinner?
    I like Floquil the best, but I have used PollyS ( pollyscale) too.
  10. jbaakko
    jbaakko Active Member
  11. myltlpny
    myltlpny Member
    I agree 100%. I swore by Poly S (which I still use a lot) and accupaint, but recently tried Floquil. I'm hooked. It spread so much easier and gave a fantastic finish. It wasn't nearly as difficult to clean the airbrush as I expected, either.
