de-soldering
Discussion in 'RC General & Getting Started' started by monsterrcbuilder04, Apr 24, 2004.
Thread Status:
  1. monsterrcbuilder04
    i need help desoldering. what is the easiest way to get the solder off of metal tabs or the board in the esc?
  2. mastmec
    mastmec Member
    Use a solder suction, they have them at Radio Shack.
  3. monsterrcbuilder04
    i tried desolder braid and that seems to be a little hard so i'll get the suction
  4. Ya, solder suckers are little tubes that suck up the solder you dont want and than spits it out. It's a handy little tool.
  5. monsterrcbuilder04
    i dont understand how it works. do you just heat up the solder and suck it up?
  6. dj6666969
    dj6666969 Active Member
    ok so desoldering is just getting rid of the solder you dont need? monsterrcbuilder04 I posted this in he Xmod section on the new xmod site
  7. dj6666969
    ok that dident make sence the site is only for Xmods duh!!!!! ok I posted this on the Xmod site there ya!
  8. monsterrcbuilder04
    lol...ok i'll check it out.THANX
  9. Ya, you just heat up the solder to a liquid, and suck it up.
  10. monsterrcbuilder04
    ok i got the desoldering braid to work ok.
  11. mr_chris04
    mr_chris04 Member
    the solder sucker is the best way to go unless u wanna really heat up ur solder and just tip ur part upside down and scrape it off, risking damage
  12. monsterrcbuilder04
    ya i tried that. it burnt the board a little
Thread Status:
