Will TMCC and DCC peacefully coexist in the same room? I run part of my layout with TMCC which includes a Command Base, TPC400's and a CAB1 wireless controller. That set up allows me to run TMCC engines in Command and older engines in conventional mode (ergo the TPC400's). I want to add a separate section (i.e. electrically isolated from the TMCC loops) to my layout and run engines on it with DCC. Will the two systems (TMCC and DCC) conflict with each other? Does it matter if the I use iwireless or hardwired controllers/cabs with the DCC? Thanks in advance for your help with this. TC
