dcc and atlas twin coil switches
Discussion in 'DCC & Electronics' started by LR&BRR, May 8, 2005.
  1. LR&BRR
    LR&BRR Member
    ok what can i use to operate my swtiches using dcc ?
  2. cidchase
    cidchase Active Member
    Use a stationary decoder such as a DS-52:
    It's not required to operate the switch machines via the DCC controller
    but it allows you to operate with only the DCC control panel if you wish.
  3. Russ Bellinis
    Russ Bellinis Active Member
    Is there any advantage to operating switch machines by dcc? In our modular club we went with cordless dcc for our locomotives, but any switch machines are still operated by whatever system the module owner chooses. Most switches are operated by caboose industries ground throws, or we use Pecos with the spring and throw the switches with a finger. Generally switch machines are used only for switches that are difficult to reach with easily damaged scenery around them.
