Dartmouth Show Pictures
Discussion in 'N / Z Scale Model Trains' started by grumbeast, Nov 18, 2003.
  1. Arlaghan
    Arlaghan Member
    Great layout and photos!
    Looked like fun! :)
  2. grumbeast
    grumbeast Member
    your right , its not N track its BendTrack, a different modular
    standard. We do share some elements with N track (height about floor and electrical standards) and I know some groups have built N-track/bendtrack converters.
    We went with Bendtrack because it does away with the pit and gets everyone outside with the public (which is a major reason we go to the shows). It also means we can setup different shaped layouts to fit the space.
    While I'm on advantages. quite a few of our members chose bendtrack because if you build two balloon modules, you have a home layout immediately that you can add to at your leisure.
    Thanks for the remarks guys, I hope the pics can provide some
    inspiration :)
  3. MCL_RDG
    MCL_RDG Member
    ...as expected (remembering the last post).
    Over the top!!!
  4. Agatheron
    Agatheron Member
    Do you have a link for Bendtrack standard?
    PS: My screen name is Agatheron, my real name is John... :)
  5. SD90
    SD90 Active Member
    Looks like lots of fun!
  6. grumbeast
    grumbeast Member
  7. Agatheron
    Agatheron Member
    That's definitely something to bookmark... thanks!
  8. Agatheron
    Agatheron Member
    One more question if it hasn't already been asked... is Bendtrack compatible using DCC standards, or is it standard block controls?
  9. grumbeast
    grumbeast Member
    its power independent. We use both DC and DCC during shows to maximise our flexibility (and the fact that all members don't yet have DCC equipment. If you are careful with crossovers (as in making sure they are isolated properly) you can run both simultaneously. We run DC on the outside loop and DCC on the inside (the inside tends to have more switching opertunities so its better for DCC.
    During shows we generally run 2 to 3 trains on a single DC block on the outside and use kill zones in certain modules to ensure that we avoid rear-ending. Of course with DCC this doesn't matter but we generally run no more than 4 trains (of course some people may be playing around on spur tracks while this is happening. I like the DC / DCC mix as there is always action for the public but there is the possibility of some operations on the inside line too (something we're looking at writing some guidelines for).
