Czech steam locomotive, series 423.0 (1921-1948)
Discussion in 'Internet Finds' started by Czestmyr, Aug 14, 2006.
  1. Czestmyr
    Czestmyr Member
    (Translated part of the text from the hobbyist magazine ABC, where I have my reference pictures from):
    "In the period of the first Czechoslovak republic ( 1918-1938 ), the ČSD (Czechoslovak Railways) had over 20 locomotive series of Austrian and Hungarian origins. Mostly, these designs were obsolete and ineffective. This situation called for lowering the number of series, thus lowering the maintenance costs. Therefore, in 1920, the ministry of railways ordered a light and universal but powerful tender steam locomotive from the First Czecho-Moravian Machine Works (nowadays ČKD - Czechomoravian-Kolben-Daněk). The first 30 locomotives were ready in 1921 and 1922 receiving the serial numbers 423.001 through 423.030. [...]
    The series design changed seven times during their production. [...] They proved very useful on the Czech local railways. Because of their load, they gained an admiring nickname "bejček" (the Bully) or "velký bejček" (the Big Bully). [...]
    During the occupation of Czechoslovakia in 1939 till 1945, our railways had to surrender 52 423.0 locomotives to the German railways (DRB - Deutsche Reichsbahn) and 9 locomotives to the Hungarian railways (MÁV - Magyár államvasutak). Thus, after the liberation in 1945, the ČSD ordered the 423.0 series from the ČKD again, in order to quickly renew the fleet, decimated by the war. The order was for delivery of 120 more engines. [...] The last 423.0 locomotives were constructed in 1948. In 1946, the ČKD workers built one locomotive more and gave it to Slovakia, whose railways were in a desolate condition after the war.
    The 423.0 locomotive of the post-war series is depicted in the drawing on the previous page. [...]
    The 423.0 series locomotive had a tractive effort of 128.5 kN and load of 750 HP (552 kW), pulling the trains of weight of 700 tons at a speed of 60 km/h (app. 38 mph) on a level track, 600 tons on a 10 per mille slope at 16 km/h (10 mph), at the same speed 300 tons on a 20 per mille slope and yet 200 tons on a 30 per mille slope at 14 km/h (9 mph). [...]
    The 423.001 locomotive is an exponate of the Prague National Technical Museum. The 423.0 series and derived 433.0 series locomotives were typical propulsive vehicles of the Czech railways from 1924 till the definite termination of steam traffic on ČSD in 1980."
    Well, that was a bit exhausting, but at least you got to learn a bit about our railways and the 423.0 series (I found that article very educating and interresting myself). I found this monography together with precise 5-view (the bottom view is not present :wink: ) drawing of the locomotive, which made me start thinking about making a paper model of the "Big Bully". I took a pen and paper and started sketching, then drew the parts in Inkscape (Linux program, similar to Corel Draw) on my computer, printed them out and started modelling. You can find the sketches of the model, some screenshots as well as photos in my gallery. The most demanding design job was thinking out the functions for the curves on the chimney and steam dome parts as well as corresponding curves on the boiler whereas the most demanding modelling job so far was putting the cab together, because it also has an interior.
    When I've finished the model, I will create simple instructions for putting the model together, and post the model somewhere on the internet for the others to freely download it.
    The only think I don't yet know how to achieve is coloring of the model. I could either export the model to raster format and paint it in a bitmap editor (Gimp rulez 8) ) or print it out in high quality on some thick paper, paint it manually with watercolors (which will be more work and is not guaranteed to be a success, but should look better, not too "computerish"). If you have any ideas or experience with the painting of your paper models, I will be glad to read a post or two from you. Yeah, of course: Also feel free to post feedback on the model and/or the techniques used in creating it and/or whatever else needs your feeding back :) .
    OK, in my gallery you can find pictures of the model, some screenshots and my conceptual drawings.
    Czestmyr's gallery
    P.S. I found out a formula of a function, that can be used to determine the shape of the bottom of an arbitrary-diametered cylinder, sitting on another cylynder of an arbitrary diameter. I think it can be useful to some of you. The formula states either: f1(x) = sin(acos(cos(x/r2)*r2/r1))*r1+hmin or: f2(x) = sin(acos(sin(x/r2)*r2/r1))*r1+hmin (the first one makes the seal of the smaller cylinder on the side, the second on the top of the bigger cylinder), where r1 is the diameter of the bigger cylinder, r2 the diameter of the smaller cylinder (the one, that is supposed to sit on the former), x the position on the circumferrence of the smaller cylinder and hmin is the minimal height of the second cylinder (that is, its height, measured from the peak of the first cylinder), f(x) then yields, for every point of the circumferrence at the position x, the height of the second cylinder. Thus, when you plot this function, scale the picture and trace it in a drawing program, you get exactly what you wanted: a rectangle with one side replaced by a strange-looking curve, which, when rolled and its oposing sides glued together, becomes a cylinder with a cut at one of its bases that exactly matches the curvature of the first cylinder.
  2. Czestmyr
    Czestmyr Member
    I have finished drawing the model in Inkscape and I also finished the virtual model in Blender. I will use Blender to produce images, similar to the one below this text. These should help potential model makers visualize the model and its parts.
  3. Richard
    Richard Member
    your design looks very promising! at which scale are you planning to build it?
  4. Czestmyr
    Czestmyr Member
    Hehe, I forgot to mention the scale? :cry: How vile of me, sorry. The scale is H0 (1:87). The model is cca. 13 cm long - which is approx. 5 in.
  5. Stev0
    Stev0 Active Member
    Looks great. Good to see someone using inkscape so well.
  6. Czestmyr
    Czestmyr Member
    I decided to make the schemes non-translucent for better comprehensibility. I've finished drawing and numbering the scheme now. Full sized version is in my gallery.
    The final step should be coloring the model. And then... :wink:
    You can look forward!
  7. barry
    barry Active Member
    Looks great, hopefully you might make a few comments on using Blender. The maths looks daunting especially to the challenged like me.
    Look forward to your thread.
    best regards
  8. Czestmyr
    Czestmyr Member
    Locomotive model design finished!
    Good news for everyone keeping an eye on this thread and my model: My locomotive design is finished and colored! The scheme is also finished, I only need to write some instructions. This is what the two A4 pages of the model look like:
    P.S. Where (meaning to which forum) should I post my new model design, when I'm done with the instructions?
  9. Amazyah
    Amazyah Senior Member
    Fantastic job Czestmyr!!!
    It would be real nice if you posted it in the forum!
    Just joking of course!:grin:
    I would probably post it in a new thread in the Parts Bin section under Commercial and Civilian Vehicles.
    I think this might be the best spot so that it doesn't get buried under more and more future threads.
