Cutting Metal Axles
rockislandmike
1,257
Edmonton AB
dayfornight.qazam.com
Hey guys, I've got 0.039" "WIRE" from a company called K&S Engineering in Chicago. I'm using it for axles for tractor trailers, but I'm not sure of the best way to cut it. I've been using my Gerber for the first four of 'em, but that seems like a bad idea long term.
Is wire snips the way to go ??? It's pretty hard for that. My Dremel with the cutting thingie on it ??? Other ideas ???
RailRon
1,602
Trimbach, Switzerland
I always use my Dremel tool with an abrasive cutting disk (NOT the tiny circular saw!) for this. Use high rpm and little pressure when touching the wire. :thumb:
However be careful and ALWAYS wear protective goggles, because those disks are very brittle! They break easily and the shards are quite sharp. I KNOW!!! :eek: :eek: :eek:
Ron
F
Fred_M
K&S makes model metals from aluminium, brass, copper, and steel. The first three are easy to cut with the clippers. The steel is piano wire and is best to cut with a file or abrasive wheel. FRED
