Crossing please help
kase
21
i am having a hard time geting my trains to go over atlas code 100 25 degree crossing please help me
kase
21
i lose power on it and when i give them a push its ok i think its the spacing between the wheels
jeffrey-wimberl
2,564
Sundown, Louisiana, USA
If you're using a short wheelbase loco, you're losing power in the middle of the crossing. A longer wheelbase loco with only 1 truck picking up power will have the same problem. I had a similar problem one time and solved it by installing metal wheels on the car coupled to the loco and ran wires from the cars axles to the motor in the loco. This allowed the loco to continue getting power even in the middle of the dead area.
kase
21
ok and can u give me a good Tutorial on how to do this????????
thanks a lot
MasonJar
It's not rocket surgery
Oct 31, 2002
5,362
Ottawa, Canada
What kind of engine is giving problems? Is it only that one (or that type)?
If you have a multi-meter, check that all rails are getting (the right kind of) power. If the entire crossing is dead, it would be far better to correct that than to permanently couple a car to the engine for extra pickups.
Andrew
kase
21
its just the middle of the crossing that has no power can i wire it in some how
if so can u tell me
kase
21
whats that mean ?????????\
i nead help i will not continue if i can not fix this prob:curse: :curse: :curse: :curse:
Ralph
Remember...it's for fun!
St. Paul, MN
I've never tried adding jumper or feeder wires to a crossing but I wonder if you experiemented with a length of wire by touching one end to a powered track connected to the crossing and touching the other end of the wire to locations on the crossing itself to see if any of these tests manage to get the loco to cross successfully. If so, then solder them up!
Good luck!
Ralph
jeffrey-wimberl
2,564
The easiest way to get power to the rails in dead area is to run wires from the live rails to the dead rails. I've done this before. Being that the crossing was already in place and couldn't be easiely moved, I had to drill holes next to the rails and run jumpers to the dead rails. Note the illustration below.
60103
Pooh Bah
Mar 25, 2002
4,754
Brampton, Ontario, Canada
kase: what are the rails in the middle of the crossing made of? If they're plastic, you can't do much with it. If they're metal, you can check that they're powered and wire them if they aren't (as j-w shows.)
If it's plastic, you may be able to add extra pickups to the loco.
kase
21
can some 1 help me install metal wheels on the car coupled to the loco and run wires from the cars axles to the motor in the loco
jeffrey-wimberl
2,564
It's quite simple really. Simply fit the car with metal wheels that have metal axles. The wheels will have the axle going directly into a wheel on one end and the other end will have an insulator where the axle meets the wheel. Install the wheels for the front truck so that the non-insulated wheels are on the right side. Now, install the wheels of the rear truck so that the non-insulated wheels are on the left side. Drill two small holes in the bottom of the car, one just back of each truck on the centerline of the car. Strip the end of a thin wire (22 gauge or thinner) about 2 1/2 inches back. run the wire down through one of the holes and wrap the stripped end around around the axles of that truck. Do the same with the other truck. Now run the wires from the car (in whatever fashion you choose) to the loco (again in whatever fashion you choose. I just drill a hole to run the wires through.) Attach the wire from the front truck to the right side feed wire in the loco. Likewise with the wire from the rear truck to the left feed wire of the loco. This should take care of your problem.
kase
21
where can i get these he wheels will have the axle going directly into a wheel on one end and the other end will have an insulator where the axle meets the wheel
what do thay call them??
4,501
Lakewood, Ca.
What is the locomotive that stalls on the crossing? If the locomotive is long enough to have wheels on either side of the crossing, you should be able to simply put in enough pick ups on the locomotive to pick up power on either side of the crossing, but we need to have you tell us what model is creating the problem. So far this thread has gone 2 pages and there still isn't any information from you on what locomotive is having the problem.
