CPR streaked lettering
Discussion in 'Weathering Forum' started by Biased turkey, Apr 27, 2008.
  1. Biased turkey
    Biased turkey Active Member
    I just tried the tip from Models Railroaders book " Basic Painting and Weathering for Model Railroaders" ( Jeff Wilson ) about streaked lettering.
    I drybrushed the same base boxcar color ( in my case CP action red ) to fade the lettering.
    I like the result , but you'll be the judges.
  2. ScratchyAngel
    ScratchyAngel Member
    Nice effect there. :thumb:
  3. Triplex
    Triplex Active Member
    With this base color, it looks like rust or dirt as much as faded paint. Which is still good.
  4. Biased turkey
    Thank you for taking some of your precious time to reply ScratchyAngel and Triplex.
    It is amazing what 2 simple weathering techniques ( black wash and dry brushing the car base color ) can do.
    It is an N scale boxcar so it is easy to overdo it.
    I'm still looking for that perfect paint brush used for dry brushing.
  5. doctorwayne
    doctorwayne Active Member
    Good looking results, Jacques. Usually, it's best to buy the best quality brushes that you can find, although I'm not sure that that applies to those used for dry brushing, which can be rough on a brush. In general, use brushes with natural bristles for solvent-based paints, such as Floquil and ScaleCoat, and synthetic bristles for water-based paint, like PollyScale or Modelflex.
  6. MasonJar
    My dry-brush brushes are cheap-o. I cut the bristles down until there's only a little left, and then use a scrubbing action to put most of the weathering on. The little plastic Testors brushes are good for this.
  7. ScratchyAngel
  8. Biased turkey
    Thanks Andrew and Wayne for the tips about the dry-brush brushes. I found a good one in my "paint brushes coffee mug".
    Jason, very interesting video. I watched it 3 times but I may have missed some point here because I never saw any segment of the video where the "Danish weatherer" uses the same paint as the base car color to fade the lettering. Very instructive video nevertheless.
  9. logicman
    logicman Greybeard
    Don't forget, people, the brushes used for oils - very good for a scrubbing effect with modeller's paints.
    Buy-by-the-dozen brushes from toyshops, pound/dime stores.
    Make-up kits can be bought cheaply with various brushes and applicators to experiment with, after which you might try them on your plastic models.sign1
    Tip: soft make-up brushes, I think they are called 'blushers' are great for dusting delicate models.
