Coupler solution
Gil Finn
1,318
Bergoo W Va
I have about 100 cars of varying quality with both horn and knuckle couplers.
I found you can trim down horn types and they funtion fairly well but it is difficult connecting them.
So rather than conver half my cars and engines, I took several cars and swapped couplers on one end so these will accoumadate anything. sign1
Now I can mix them up for a frieght consist or make a whole coal drag with about 25 hoppers. Same with log cars and my Shays.
Glen Haasdyk
1,283
Kelowna, BC
I've done this with my passenger cars until I get around to changing them all over. I also have and Athearn F-7 b that I used as a conversion car, but to be honest I hardly ever use it since almost all my cars have been switched over to Knuckle couplers of some kind
Ralph
Remember...it's for fun!
St. Paul, MN
I'm right there with you Gil but what I did was set up a couple of locos with one magnetic and one horn hook. That way they can each run trains of one sort or the other. Obviously i can't do switching moves that invovle having the loco run around the train and pull out cars from the rear...but I have other locos that are fully equipped with one form of coupler or the other.
Ralph
Jeffs_Railroad
48
Connecticut
Hi all - I have run into a similar situation with horn and Knuckle coupers on low quality rolling stock. Was going to convert the horn to knuckle but noticed that the rolling stock I have from 23 years back do not allow access to the coupler without doing damage, unless I replace the entire assembly. Would appreciate any suggestions. Do not feel the cars are of quality to replace, considering buying new rolling stock.
Gil Finn
1,318
Bergoo W Va
I have super glued one coupler on a car several times and it seems to work OK if it only one end and independant of the trucks.
