couple of pics of one of my Rustlers snaping off t
Discussion in 'RC Onroad Forum' started by timrock, Mar 25, 2004.
Thread Status:
  1. timrock
    timrock Active Member
    [file]ShowLetter2.jpg,4111,,0[/file]
    [file]ShowLetter4.jpg,4111,,0[/file]
  2. monsterrcbuilder04
    nice truck. that electric?
  3. timrock
  4. monsterrcbuilder04
    nice! what motor and esc do u have. also u running 6 or 7 cells
  5. timrock
    that was running a speed control that i made.it was running 9 cells with a 14 turn motor.
    now i have a Streak ESC and it does the same thing on 9 cells.
    i want to run 20 cells so i plan on useing 2 Streak ESCs
  6. monsterrcbuilder04
    nice job on the speed control and with the 20 cells and 2 esc u should be flying. do u no how fast it goes
  7. timrock
    i had it well over 100mph a few times.ran 16 cells with the speed control that i made.with a 12turn motor.
  8. timrock
    when it was set up to hit those speeds,it wouldnt do wheelies.the gearing was to high.
    it was geard very low in this pic.if i ran 16 cells with that gearing,the truck would flip over as soon as you hit the throttle.somtimes traction is not as good as other times and i get alot of wheel spin off the line.
    at one time i had it doing 0-50mph in less that 3 seconds.
  9. monsterrcbuilder04
    thats impressive. would u be interested in making me an esc or giving me scamatics to make one. im not in it to break any records. i just want to show some insane speeds to my friends and try to get them into the sport. i only know one other kid that has a car and thats a savage. all my friends want nitro cause they think its faster and better but cant afford it.
  10. timrock
    electric is faster if you make it faster than Nitro.and is cheaper.
    how would you want me to send a scamatic.i can draw one with a pencil on paper and Fax. it to you.
  11. monsterrcbuilder04
    u could also email it to me
  12. monsterrcbuilder04
    ive got the bandit wich is almost identical to the rustler. i was wondeing where u fit all those cells and if u built a cover for the esc?
  13. timrock
    i could e-mail it to you but i would need a scanner which i dont have.
    there are places all over the chassis where you can put cells.i use Velcroe straps to hold the cells in place.
  14. rockn82
    rockn82 Marx Brother
    Use Paint and then save it as a .JPG and attach it to an E-mail.
    how about some pics without the body?
  15. timrock
    i cant draw with paint.well not with the mouse.you can get an electronic pen,cant you
    i only have four pics with the body.
  16. A J G 3 6 6
    A J G 3 6 6 Member
    You dont have a camera?
  17. monsterrcbuilder04
    i think it would just be easier for u to draw by hand and fax it. unless uv already started
  18. monsterrcbuilder04
    does it have a motor or cell limit
  19. monsterrcbuilder04
    so if i put like 24 switches in it i could run like 35 cells
  20. timrock
    sure.you can run that many cells but to one motor,it would be too much.you would go through brushes as often as you go to the bathroom.
Thread Status:
