Discussion in 'RC Drifting and Setup' started by xsquizet_drifter, Jul 29, 2005.
  1. how should you countersteer do you do full lock or you do moderation.
  2. SpArKeY_STi
    SpArKeY_STi Guest
    Depends... you only should only use oppisite lock when needed. Some instances you wont need any counter steer, some you'll need quite a bit. It all depends on how fast your taking the corner, corner type, and your set up.
  3. VDubbin
    VDubbin Guest
    Pracrtice woith both and see which one works best for you! there's no hard and fast rule about it...
