Cookie Cutter Method
Discussion in 'HO Scale Model Trains' started by andywyeth07, Aug 27, 2006.
  1. fsm1000
    fsm1000 Member
    I used cookie cutter and have pics [and tutorial] on my site showing how. You did ask for pics :D
    Ed, yes you still can use it. My edges are nailed down as well. :)
  2. 60103
    Amrap: If you have the plywood lightly tacked to a framework, you have to watch on the cookie cutter that you don't run the jigsaw into the framing members.
    Generally, with cookie cutter you expect to leave the unraised bits down at elevation 0. BUT there's no reason you can't use cookie cutter variations 2b or 2c where bits of flat board are removed.
    There is a further variation where all that's left is track bed and some outside walls and the scenery is suspended in the middle.
  3. Jim Krause
    Jim Krause Active Member
    You don't have to cut your curves in one continuous piece. you can use smaller pieces of plywood and make a complete 180 degree curve out of several pieces. Saves a lot of cost that way. By the way, this is the way layouts used to be built in "the old Days" when wire and plaster were the primary scenery materials. It was called open grid benchwork
  4. jwmurrayjr
    jwmurrayjr Member
    You can use the cookie-cutter method on 1/2" foam too.
    Stick to the blue foam for risers too.
  5. Glen Haasdyk
    Glen Haasdyk Active Member
    I reconize that layout! Thats the Jerome and southwestern of John Olsen isn't it? I've had that book on that for twenty years now and I still get insprastion from it. It looks like you've done a good job on it.
