Discussion in 'Getting Started' started by GraemeK, Feb 28, 2011.
  1. GraemeK
    GraemeK New Member
    I currently use 2 hornby standard controllers on my layout.
    (1x 16vAC + 1x 12vDC track output each)
    I was considering switching to a Gaugemaster Model D.
    (1x 16vAC + 1x 12vDC + 2x 12vDC track output)
    But, the big question is, would it fit my control panel?
    The space I have available is 180mm x 265mm.
    The reason for the change is that I need something a bit more robust and suitable for the job.
    I am aware of the different volt accessory outputs. I actually feel that this would be more convenient!
    Any guidance would be greatly appreciated. Thank you.
